1L243 wrote:
Was wondering if any use a gauge on their propane tanks. If so what kind and are they accurate?
Wireless monitor inside the trailer would be nice but probably overkill...
Depends..
External gauges are a hit or miss thing.
Like this type..
![](http://ecx.images-amazon.com/images/I/91pOx6xYEsL._SL1500_.jpg)
Which works when you splash hot water down the side of the tank..
Or this type..
![](http://ecx.images-amazon.com/images/I/51iXIoyEeRL.jpg)
Which uses propane pressure, tends to not give much warning, therefore not accurate.
Or this type..
![](http://ecx.images-amazon.com/images/I/615qV9%2Bx-pL._SL1500_.jpg)
Which is basically a weight scale, but tends to be very accurate.. The downside is you must disconnect tank and remove from tank holder.
The ONLY other accurate tank gauge is an INTERNAL FLOAT gauge..
Basically the valve assy must be removed and a new valve assy which has a internal float must be installed..
IF you can find one it will not be a DIY project, the tank must be emptied by a pro, valve removed and new valve installed.. Then tank will get pressure tested and re certified and refilled.
Not cheap and will cost a lot and in most cases not worth the hassle.
If you have a two tank setup with auto change over why worry about it.. The changeover will indicate when a tank is empty, then you rotate the valve over to the full one and you can remove the empty tank.
Looks like this..
![](http://ecx.images-amazon.com/images/I/61wesZXajbL._SL1000_.jpg)
