I have noticed on my new 2016 Ford F250 there are gauges without numerals on them. Does anyone know the values too these gauges starting from left to right on the dash: Turbo PSI 0-40; what is a...
I agree that after you drive the truck a bit you will see what it normal. I use mine just to get a rough estimate of how things are. The turbo boost doesn't move much unless accelerating quickly or towing a trailer. The trans and coolant temp will just hover around the mid point once warmed up. When the data display shows both of them hitting 200 degrees (roughly) the needles are pretty much in the middle.
