I like my Edge Insight CTS. As you know, you can make it show analog readouts and it looks much like an analog gauge. Best thing is you can set alarms on just about everything and not really have to pay attention as much since the alarm will go off when the parameter reaches the set point you select. Example, when my post NOX EGT reaches 900F set point I know my regeneration is getting ready to occur. I have many alarms set for important parameters I want to monitor. Analog will also work, but you can't set alarm parameters. Good luck.
