boingram
Nov 22, 2014Explorer
GAWR DENALI
Looking at 2015 denalis...the rear GAWR is 6200#. How do I determine what the NETis after weight of truck and cargo. ..guess what I need to know is how much truck weight ls rear axle carrying. Tryi...
BenK wrote:
Nothing can be done with a wife other than trading her in on a better model... :B
You two need to decide who is going to be happiest with the other NOT happy...
Here is how the ratings system looks like in graphical form to help
you understand enough to do the simple math using the OEM's data
On that data...best to have actual weights and if no actuals, then
use their heaviest possible (GVWR's)
Dry and curb are useless numbers in the real world. They are the stripper
models for marketing 'max tow', etc
Here is the diagram from this thread: Maximum payload calculationBenK wrote:
From another thread, but applies and may help this OP understand how the ratings system worksBenK wrote:BRCajun wrote:
snip....
With all of you veterans & experienced 5'ers out there, I am hoping to get some honest, quality feedback as to which truck will give me and my family the best performance (tow capability {up hill and down hill}, mpg, braking, suspension, durability, ride (comfort/noise), longevity and anything else.
Thank you!
This is where the OP must be learning that his question is very, very subjective
Sprinkled with 'some' techie stuff, but clouded by opinion (that subjectivity
again)
These comments 'are honest, quality feedback' on the 'best performance'
THOSE individuals believe in
My advice to the OP:
- Read up yourself and learn
- Read lots of the past posts from the advisors to see how their opinions/values/etc match yours...or NOT
- Or learn the hard way that most learn from...AKA 'Hard knock school'...which is expensive
Bottom line is to do your own research. DO NOT use marketing, but
put together real specifications...knowing that there is fine print
that modifies all automotive specifications
As you have found...some recommend a 10K GVWR...others say a 8.6K GVWR
will just be fine, etc, etc. I do NOT like to use marketing badging
as it has no definitive reference. A 10K GVWR is a 10K GVWR...a
1 ton dually varies in GVWR from OEM to OEM...form model to model
To some the axle shaft dia is important...others not and just the
GAWR from the TV OEM is what matters...others want to know the
OEM's GAWR supplying the TV OEM...
Learn how the ratings system works. Then decide if you believe in the
ratings systems or not.
If not, then do whatever
If yes, then learn how they work
This is how that ratings system looks like in graphical form:howmuchcanitow howmuchshoulditow
wheelndeal wrote:
Hi, i am new to the truck world. We really want to go camping but want to make sure we get the right truck.
I am looking at buying a 2014 sierra 1500 double cab 5.3 L with 3.42 gear ratio.
I want too buy a camper that weighs 6630 lbs dry weight and 7458 lbs loaded with water, gear, food, etc... I think the hitch weight is 845 lbs
passenger weight is 680 lbs
I also want a quad and they vary from 700 lbs to 800 lbs
Is this truck going to work for me or do I need a smaller camper(I did consider a toy hauler but my wife hates them so that's out of the question)
I should also mention that I need the ramps for the quad and generator that i havent calculated the weight for.
Sorry if i am not clear or seem to be a little everywhere. I am new to this and I am out of my depth here.
Thx for anyones input
