ndanecker
Feb 10, 2021Explorer
GD Momentum 395ms with Ram Megacab
I believe we have the RV narrowed down and its the Grand Design Momentum 395ms. Also have a new tow rig on order (1/8/2021) and its a 21 Ram 3500 Megacab DRW. I know its a short bed and will need some care in turns unless you go with a slider or other device to limit (or really increase) cab to trailer distance.
So - one option I would lean towards is the Reese Goosebox. I have the GN prep included because I want the holes clean and like the puck system. Was thinking about swapping out the GN hitch for a B&W one that has the square hole so I can use the 4" offset ball. Million dollar question is do you feel this will get me close to 90* or at least to a point where I don't need to pucker-up every time I make a wide turn or try backing into a spot.
Really don't want to do a slider.
Suggestions and comments welcomed. Thanks guys.
