MFL
Feb 10, 2021Nomad II
Whatever hitch setup you decide on, if you can be close to 40"s from back of cab, to hitch pin center, it should work. Length of pinbox, amount of curve to front of trailer, width of trailer front, all things to consider.
One thing to keep in mind...no sense to turn/back to 90 degrees. The closer you get to 90, the more you are twisting/pushing sideways, but not backing. It is always best to pull ahead a little, straighten, then back again at a lesser angle.
Jerry
Jerry
