cummins2014
Feb 12, 2021Explorer
MFL wrote:
Whatever hitch setup you decide on, if you can be close to 40"s from back of cab, to hitch pin center, it should work. Length of pinbox, amount of curve to front of trailer, width of trailer front, all things to consider.
One thing to keep in mind...no sense to turn/back to 90 degrees. The closer you get to 90, the more you are twisting/pushing sideways, but not backing. It is always best to pull ahead a little, straighten, then back again at a lesser angle.
Jerry
Jerry ,we more or less covered this on another thread , 40 inches is rear of axle center on a Megacab. Yes it may work, but the biggest thing to consider on a 6'-4" bed is getting too far back off axle center , yes lots to consider
I can speak from experience no slider is needed on the right setup with a Megacab.
