Lantley
Feb 17, 2021Nomad
ndanecker wrote:Lantley wrote:
I wasn't referencing anyone in general. These threads appear all the time.
It's not that complicated to get the right truck for the application.
We often make this a subjective topic but the towing parameters speak for them selves.
If your trailer weighs Y. Your truck needs to be able to carry Y. Except too often someone wants to use a truck that can only carry up to X, not quite Y.
They will list a host of reasons why X can be made equivalent to Y or why you really don't need to use a Y capable truck cause X is just as good.
This towing at the edge ideology can be found across all kinds of trucks 1/2 tons, 3/4 tons, 1 tons and duallys. Short beds vs. long beds are also part of edge towing.
Choosing a towing combo is a straight forward process if you use a calculator or in the case of a back window a tape measure, however often times we use everything except a calculator or a tape measure.
We make subjective choices based on questionable logic that often leads to getting it right the 2nd time or learning the hard way.
When I went from a TT to a fiver. I knew I wanted a big fiver so I bought a dually right off the bat.
It wasn't that I was in love with a dually, but the math told me if I want to avoid the upgrade game than a dually would allow me to shop for any trailer I wanted without being on the EDGE of my limits.
Why are you even bringing weight or size of truck into the conversation? Megecab short bed has near identical capacity of a crew cab long bed (which I've owned an 04, 13 and 14) which exceeds the requirements of the 395m. Again - weight was not the topic of discussion so leave it out please.
You missed the point. Capacity is one thing hitting the cab is another.
But they are both can lead to the the same issue. You can get a truck that requires puckering up when things get tight or you can get a truck that delivers carefree towing at all times.. no puckering required.
You ask will I need to pucker up on tight turns?
Without a slider that depends on your definition of tight.
