GoPackGo
Apr 14, 2016Explorer
blt2ski wrote:
One needs to remember, torque is not always what your want. HP is also needed. At the end of the day, even back 20 years ago, one geared a rig so you had the HP needed in high gear to move a rig. That is why in navistar runs at 2500 at 60 mph, as that is where it produces the hp to move 26K lb, around 150hp. Then again, my motor produces a peak 175/335 hp/torque. A 3.73 gear set would be nicer, but i could not run at 55-60 in high gear, which for me is direct.
Gearing in trans can make up a lot for what is in the pumkins.
I'm also not one for running lower rpms in dod, it take hp to turn a OD and DOD trans. Two setups turning 1800 rpm, the one with 4.56 gears running in dod will be potentially using more fuel than a rig in direct with say 3.08 gears. BUT, to get the load going, the 4.56 setup may need a 6-1 first gear, the 3.08 a 10-1 first gear. At the end of the day, it is being in the correct final ratio for how you tow, pull etc, than it is what gear ratio is in the pumkin. You need what is in both the pumkin and trans to know what will be correct for YOU!
i would take the lowest set. Then again, i only drive up to 55-60 mph for the ost part, as it is not legal to drive 70 mph locally, so the lower gears give me a better rpm at 60 than the taller ones in DOD!
Marty
What in the world do you mean when you say 'DOD' ? Let me restate that - I worked for DOD for 30 years and we never once referenced our parent organization and gear ratios in the same sentence. Help me understand what you are stating !
44,071 PostsLatest Activity: Aug 30, 2026
