KKELLER14K
Nov 16, 2022Explorer II
The question: Is the Furrion A and B selector both on?... (As indicated by the upper center display showing 1 and 2). If so... Are you are only hearing one set of speakers inside? Check the balance, (by pressing the volume knob and rotate it to AUDIO ADJUSTMENT). Check to see if fade front to back is also available. Most setups use a fade to adjust sound levels on the outside speakers, (which I prefer) but in your case I think it is the A&B function situation in my opinion.
44,070 PostsLatest Activity: Sep 18, 2026
