valhalla360
May 31, 2022Navigator
engineer40 wrote:
Hello all! I just created an account, but I'm excited about my new (used) camper and I plan on becoming a regular on this forum while I learn. It's a 1994 Viking 10ft truck bed popup camper. At this moment, I'm feeling over my head with some things. I'll say thank you in advance for any help you provide. Surprisingly my camper came with all of the original paperwork. I've read through it but still have some very basic questions.
-My camper didn't come with a battery. I found the spot to hook one up. I found where I flip a switch from AC power or battery power. Does the built in inverter automatically charge my battery when I'm plugged into AC power? Does my truck alternator automatically charge my camper battery if the truck is running? Do I need to worry about it overcharging and frying an expensive battery?
You don't switch from AC to battery power (ie: DC - direct current). They are two parallel systems that do different things. It's unclear what the switch is for. It might turn on an inverter which takes DC power and inverts it to AC power but that's unclear and assuming a single 12v battery, very limited. It might also be a switch to turn on the converter (aka: battery charger).
-Do most hot water heaters in campers work off LP or electric? The owners manual calls it a "Gas and Electric water heater". But the instructions read like gas "or" electric and not both. I do not see any way to switch from gas or electric. Maybe there is a way and I'm just not seeing it...
Most have either capability and usually it's possible to run both but they are independent heating systems.
-Also in regards to the hot water heater, the owners manual says to make sure there is water in the heater before electric is turned onto the camper or the element will burn out almost immediately. Does that mean if I don't have water in the camper I literally can't plug it into AC power? It's very confusing. I'm nervous I've already burned out the element because I had it plugged into AC power in my garage.
The electric heater is a resistance heater. Kind of like a toaster but designed to operate submerged in water. Water will quickly absorb the heat. Air can't absorb the heat nearly as fast, so it will overheat and burn out. Usually, just the heating element goes dead and needs to be replaced at that point. There should be a switch either inside or on the exterior of the hot water heater to turn off the electric, so if it's empty, you can turn on the AC electrical system without damaging the heating element.
-It has a Dometic fridge. Do most camper fridges have the option to work off of AC power or LP? The manual only talks about LP or temporary battery power (not long term). I think it would be weird if the fridge doesn't work while plugged into AC power because I would want it getting cool while packing to leave home.
Absorption fridges operate by heating an ammonia solution (I know it seems backwards). The fridge doesn't care where the heat comes from. They pretty much always have the option of a propane flame and others come with either an AC and/or DC heating element. Propane will last a long time (as in weeks from a single tank). If you are connected to shore power, an AC heater eliminates propane consumption and since most campgrounds include electricity for overnight stays, you pay nothing extra for it. DC heating element is less commonly used as a single 12v battery won't run the fridge for long. It was an option when traveling and the truck alternator could keep it charged (assuming you have the RV connected properly to the truck). It would be possible to add a large bank of batteries and solar but not the most practical solution when propane lasts so long.
Not all absorption fridges include an AC power option but just turn on the propane. Also do it the night before as these fridges take a long time to cool down. Also when loading, try to make sure the food you put in is already cold. If you put a bunch of warm food in the fridge, it will take a very long time to cool down.
I hope all of these questions make sense. Thank you for any help. I'm a single dad. My kids and I are excited to get out and use this, but it's overwhelming even after I read through the Owners Manuals. Thanks!
As others have noted, without pictures and/or model names, it's a bit of guessing as to exactly what you have.
