dbarrett's avatar
dbarrett
general wiring of ground or neutral
For new installation in my RV. I have a double pole double throw switch labeled L1 & L2, A1 & A2, B1 & B2. Please verify or instruct if I understand this. Run the hot from the breaker to L1. L2 is the ground or neutral? If that is correct than L2, A2 and B2 can be joined and run to the neutral/ground bus bar. Is that correct? Dino
