dbarrett wrote:
Does that sound right? Dino
What sounds right is.....an answer you got in your OTHER thread....
Don't change the built-in charger at all.
Connect the battery clamps from the bigger charger to the batteries.
Plug in the bigger charger when you need it. The smaller charger should see the higher voltage and shut down.
The wiring you propose is going to be difficult because of the one built-in panel and potentially dangerous if you do something wrong.
That should be pretty much evident because of the variety of answers you are getting about how to wire the switch.
The absoulte best way to accomplish what you want is to replace your built-in with a 3 stage with the much higher bulk charging rate that you desire.This would make the whole operation automatic for everybody, including the next owner.
And....it causes unnecessary confusion and wasted effort to fracture a discussion by starting a new thread. MUCH better to just continue the original.
And I repeat because it is important:
You NEED a meter or a little diagram of the switch before you do anything. If you don't, you risk personal harm and equipment damage. Having a switch with a center OFF risks leaving it in that position by accident and not charging the batteries at all.
