deltabravo
Mar 17, 2021Nomad
Matt1221 wrote:
would it bog down the generator like vampire & run gen at high load all the time? Does the rv's inverter eat up electricity?
THe speed of the generator is dictate by the amount of power you are using. If you have a lot of AC appliances on, then yes, the generator will run at a higher RPM, if it's an "inverter generator".
The RV's inverter has no correlation to the generator. Did you mean the RV's Converter (which is a charger)?
44,070 PostsLatest Activity: Sep 18, 2026
