time2roll
Mar 17, 2021Nomad
Do you have a 50 amp RV? Does the generator produce 120/240 volts or just 120 volts? The effect can be different depending on how these two systems match up.
By RV inverter "eat up" electricity I am not sure if you are asking if it will drain the house battery fast and you will need to frequently recharge... or if the inverter/charger will consume much of the generator power to charge the house battery and cause the generator to run at full speed and volume.
If you post the inverter model number it will help. Do you have a propane fridge or a residential compressor fridge?
The 12 Volt Side of Life
44,070 PostsLatest Activity: Sep 18, 2026
