SoundGuy
May 06, 2018Explorer
badsix wrote:
how do I find out what my LRA IS?
Check your A/C documentation or look it up online using your unit's make / model. That said, why would you care? - it's going to be somewhere in the 50 to 70 amp range, there's nothing you can do about it anyway, and other than being a curiosity it won't have any bearing on your choice of genset other than to perhaps convince you that you need to go to a larger than necessary genset. JMO, but if weight is your major concern I'd be considering the new Honda EU2200i which weighs the same 50 lbs as the earlier EU2000i and add a Micro-Air Easy Start Soft Starter Kit to the A/C. You won't have electric start but this sure would be a much lighter option than a Champ 3100 or 3400.
