Defens wrote:
westend wrote:
I have the same genset with the same B&S engine. It is absolutely the loudest machine I've ever had. It does do what it's supposed to do.
Make sure any adaptor you get takes the 240V available at the machine's 4-prong receptacle and only outputs 120V through the adaptor. Good luck!
Beat me to it - emphasizing to make sure that you're sending only 30 amp, 120v to the TT. My understanding is that most 50 amp trailers run both hot legs (plus neutral and ground) into their power center, balancing the load between them. A 30 amp trailer only has one hot leg to the load center (plus neutral and ground). So, I'd be fairly certain that the adapters you're seeing drop one of the hot legs - but check to make sure!
OK - but how do you check? Meter?
