2012Coleman's avatar
2012Coleman
Explorer II
Nov 15, 2016
Generator Question
I have the generator pictured. Bought it before I had a camper to power stuff during outages due to weather in Florida. Has powered my home refrigerator a couple of times, literally saving my bacon.
It came with a long heavy cord that has a plug that fits into the 30A outlet below - the other end having 3 or 4 120V plugs.
Now that I have the TT, I have always wondered if I could power the AC on my TT, and if so, is there some kind of adapter that fits the 30A outlet to my 30A plug?
  • RoyB's avatar
    RoyB
    Explorer II
    I know this is not your question but once you get it going then you have to worry about where you will be able to use it at the public camp grounds and places.
    Here on the East side of the US I am always running into places using my Honda 2KW portable generator that have generator use restrictions which varies from place to place but most often it is a couple of hours in the morning and a couple of hours in the early evening. Not many places have it allowed during the whole day and very seldom see it available after 8PM at night... Some of the Natl Forest areas now have it allowed in certain spots from 8AM to 8PM but never after that. Being built-in you might get away with running more hours.
    Thank goodness for me I can live without air conditioning and high wattage microwave operations that allows me to get by just fine using my additional batteries and beefed up wiring on the trailer and changed over lightning to LED units...
    We can do almost everything we at public electric hookup sites with the exception of the Air Conditioner and the High wattage microwave unit.
    I am all planned out to run the one day/night off my batteries then at 8AM the next morning during breakfast I can run my 2KW generator to connect to my trailer and recharge my battery bank back up from its 50% charge state to its 90% charge state in a three hour generator run time. Then i am good again for the next day/night run off my generator...
    This is what we have been doing since 2008 with the off-road POPUP trailer camper camping off grid out of Virginia up and down the Blue Ridge parkway and the East and South East coastal areas mostly at public camp places. TN smoky mtns and the high country areas in the VA-TN-NC-GA-AL are my favorite places to go...
    I am thinking about adding a few solar panels to reduce some of the time my generator has to run to keep my batteries up when in high sun.
    I would imagine those Troy Built generators are very loud to use in the public areas. Folks frown at me using the Honda Inverter type generators sometimes...
    Roy Ken
  • Ivylog's avatar
    Ivylog
    Explorer III
    You need a four prong twist lock adapter, not a three...the link above will NOT fit your generator. If your trailer is only 30amps then this one or this one will do on Ebay.
    If your rig has a four prong 50 amp cord then you need this one. If you are not in a hurry then for $26.
  • That genny would probably power TWO AC's!!! And yes, there is a small adaptor that plugs into the genny and your power cord from your camper will fit. Any store that sells gennys should have them.
    Edited as the spell check didn't like my abbreviations!!!
