RSD559
Mar 07, 2017Explorer
The Honda EU2000i will put you out about $1000. So make sure it works before you pull the trigger. You can probably rent one to check it out. Another option is the Champion 2000 which will run you about $450 at Walmart.com. Not as quiet, not by much anyway, and it has higher surge power rating. The 2400 watt Yamaha mentioned will run you a little over $1220. You might be able to find one to rent for a few hours to check it out. If your needs grow in the future, you can buy a second one of any of these and run them in parallel and come close to doubling the output. All of these will run forever, if you take care of them. Good luck!
