HioSSilver's avatar
HioSSilver
Generator question
How long can the propane generator run on fuel in a tc with 2 5 gal propane tanks? My dad just bought a lance 971 and we were wondering.
  • 2.5 gallons of LP is 10 lbs. That is a pretty small tank.
    Also, most (all?) dual fuel generators make less power on LP.
  • HioSSilver wrote:
    Thanks for the replies. This is one of the propane ones that came in the lance 971. We were just kinda curious. I haven't used a propane generator before so i have no clue how long they run. And of course i know the fuel usage load dependent. Just kinda a average run time. I mean for the most part one probably don't run the generator much unless the ac is running.
    You should hope its a Onan 2500 and not a Generac.
    They can both be expensive to repair.
    I T'd this hose into the pressure regulator and one of the LP tanks. Its my backup in case I run out.
    Those horizontal bottles are expensive and this way I can take an extra bottle from my BBQ.
  • Propane usage on average is about 130% of gasoline usage of the same generator, but some poor conversion can have the % even higher.
    How it can be different - I can compare gasoline models.
    The 4500W Generac would use 1 gallon of gas per hr with 1/3 load.
    My Honda 3000 will run 6 hr on the same amount of gas, while running AC, or probably couple of days for battery charging and coffee maker.
  • Thanks for the replies. This is one of the propane ones that came in the lance 971. We were just kinda curious. I haven't used a propane generator before so i have no clue how long they run. And of course i know the fuel usage load dependent. Just kinda a average run time. I mean for the most part one probably don't run the generator much unless the ac is running.
  • First check what kind of generator it is and go to manufacturer site for technical data. Members experience will start another kind of diesel v/s gaser debate.
    When inverter generators really run long time at low load, the high speed generator will suck it load or not.
    Than higher load will increase consumption.
  • Fuel consumption is very dependant on the load on your generator.
    My generator sips fuel until I turn on the air conditioner then it guzzles fuel.
    My best guesstimate is that I use about 4 times the fuel when the a/c is running than when it isn't.
  • According to Onan a 2500 Onan at half load should use about .3gl per hour.
    So 10 gallons should last 30 hours. I hope that's right. :)
