Passme's avatar
Passme
Generator recharges batteries
Hi everyone, I use my Honda 3000is to recharge batteries but for how long do I run geny? I have 2 6V batteries with 206 Ahr total. I've learned that batteries max charge amps should be 25% of Ahr rating so my WF-9855 converter is a good fit, puts out 55 amps. So if my batteries are say 50% discharged would 2 hrs generator run recharge my batteries enough to use? This assumes no significant 12V draw on the converter so it's delivering 50+ amps to battery bank. Trying to weigh the costs of continued generator use compared to the solar investment. Perhaps a combo of both would do the trick. I know it takes hours to reach 100% charge but aiming for that 80%+ range, reuse lightly then recharge. Repeat. Any thoughts? Thanks for the feedback.
  • Yeah you're assuming the WFCO will go into boost mode but it probably won't.
    I have an IOTA-55 for charging and shut the WFCO off. Two hours a day with my Honda 2000 keeps me and my batteries happy. Even an hour a day will get me through.
  • 9855 WFCO? Probably 12 to 24 hours unless your 9855 actually goes to boost mode and you see 14.4 volts. If you do see boost watch for 14.2+ volts on the battery and then run one more hour to get about 90 to 95 percent.
    Most likely you will get 13.6 volts and amps will begin tapering off within 10 minutes for a trickle charge.
  • Oh boy. Two hours of generator noise. My batteries are full before noon most days....noiselessly. In fact it's almost 6 pm and solar is still working lightly...noiselessly.
  • "would 2 hours charge enough to use?"
    The short answer is yes, 2 hours would be a significant charge at that rate to that size bank and you could certainly continue using the batteries.
    However, I suspect something more like 3 or 4 hours would be a better charge. The 50 amps will tapper as the batteries recharge.
    Do you have an amp meter? I'd run the generator until the batteries are taking only 10% of their capacity (20.6 amps).
