smkettner wrote:
^^^^ Yes and the Panasonic inverter series is different.
Follow the link for actual wattage consumption measurements.
Thanks for the attribution.
Here is the link to the Panasonic MW Model
NN-SD372S that we have.
We really like that it can hold a full-size dinner plate and a full plate sized cover. Our previous 700W MW was too small for either, plus it used 1200W and required the Yammi 2k genny.
We also have two other appliances that can run under 1000W on the inverter; a Mr. Coffee that uses 640W and an induction stovetop that uses 450W on power setting 4. We can cook a silent breakfast from our single 100AH AGM battery.
We recently cooked 4 eggs over-easy, 4 toast, 2 pots of coffee, and 6 minutes of coffee warmups in the MW with the inverter. Total run time over 32 minutes.
With the right appliances you don't need a 440AH battery bank.
HTH;
John
