mdprowash's avatar
mdprowash
Generator that won't break the bank..
Is there anything in the $500 range that has a respectable decibel level?
  • Whats the point of an inverter generator if it's supplying power to your trailer?
  • Champion 3100 inverter generator if you want to run A/C but more then $500. Another option that is louder is the 3500 champion non inverter can be bought for less then $500.
  • The Champion 2000 inverter will probably not run an A/C, depending on the size of the air conditioner.
  • gbopp wrote:
    What do you want to run with the generator?
    The Champion 2000 Inverter has a good reputation.
    A/c if necessary..
  • What do you want to run with the generator?
