naturist
Oct 02, 2015Nomad II
My guess, absent gross mistreatment in the form of bad/no maintenance on your part, the reason for the premature demise of the 5600 watt unit you used up in just one year is that you ran it pretty much full capacity a lot. So the first question is whether the 5600 watts rating was surge or running watts. Which ever it was, get the next larger size, and don't attempt to go cheap with a smaller capacity generator, whatever its brand.
On the other hand, if the previous unit bit the big one because of zero or bad maintenance on your part, the only thing that will save the next one, regardless of brand, is proper maintenance.
