crosscheck
Mar 10, 2016Explorer II
HMS Beagle wrote:chobe2 wrote:
Thank you everybody. What I'm thinking is to install a very small 600-700w microwave, maybe a 1500w inverter and at least one more battery. We would only use the microwave for a minute or two at a time. The AC would be a luxury for when we have shore power. Does that sound feasible or do you think we should get a built in generator, see what our needs are and go from there? I've done a lot of reading online and it seems like everyone is going more toward beefing up their batteries, adding solar and using a generator less.
The best way to annoy your camping neighbors is to run a generator.
For what you are contemplating, a solar/inverter setup will work just fine, especially backed up by the fact that you (like me) keep moving. A microwave uses a lot of power for a very short time, the impact on batteries is usually small. The battery bank must be large enough to source the current, but capacity usually isn't an issue. Even a hair dryer isn't on that much, and can be run from an inverter. The AC is impractical without a very large solar array or generator (or plugged in).
What I would do (and did, in exactly the same situation): Put in two high capacity batteries, 6V golf cart batteries in series are perhaps the best choice in price/performance. Install a 1500 - 2000W inverter, for most things a "modified sine wave" is OK, "true sine wave" better but costs more. It is useful to get one with some battery State Of Charge monitoring features. Put two 100 - 150W panels on the roof through a good charge controller. Change out the light bulbs for LED replacement bulbs - buy one first and make sure you like that brand/color before buying a bunch, they vary in light output and color temperature. Upgrade the charge capability from the truck. This involves running a larger charge cable separate from the 7 pin, through its own connector (a lift gate connector works well). There are many threads on how to do this. The reason for this is it will allow a much quicker charge when you begin driving, if the batteries have been discharged more than 20% or so. The wiring in the 7 pin cable does not allow for a heavy charge.
I have just this sort of setup. Even without any charge from the truck at all, since putting the solar in place I have not plugged the camper in anywhere, and it stays charged. I used it for a year that way with no other source of charge. If parked or driven in the sun, after a sub 30 degree night with the heater on, by 11 AM the batteries are topped up again. This is running lights, charging the phones/laptops, running the furnace, etc. without particular care. I normally do plug in the truck charge cable, and you would need it for a series of cloudy days or parked under trees.
Once installed, the system is maintenance free and silent. Your camping neighbors will like you. You don't need to think about starting the generator because you want to dry your hair or pop some popcorn in the microwave, or charge your laptop. The 110V is always available just like home. When the camper is stored you do not need to worry about periodically charging the batteries, they will be automatically topped up and maintained. It is really a much better solution than a generator, for every purpose except running the AC.
I agree with everything Beagle has to say. We are in season 6 with 330W solar, 2000W inverter 4 Agm batteries and an all electric fridge. Almost 100% of our camping is dry/boondocking and although we carry a 2000W genny, never use it. The only thing we have changed over the years is started at 190W, now 330W solar. We do not have A/C. Our fridge is the largest daily draw of battery power. We use micro very little, hair dryer every day, small appliances, electric toaster ,charge all electronics, electric roof, sometimes jacks when removing TC, radio, heater to take chill off in the morning, LED's everywhere and 2 fantastic fans if it gets really warm at night.
If you were always in the shade or you used the same amount of electricity in your RV as you would if you were at home, or boondocked in a lot of places where you needed A/C then an all solar/ truck alternator system may not work all the time and a generator would be needed.
For us, this system has worked very well even though it was a bit pricey at the start. (we already had the generator from another TC). Good luck on whatever you choose.
Dave
44,071 PostsLatest Activity: Aug 30, 2026
