ticki2
Mar 14, 2016Explorer
DiploStrat wrote:ticki2 wrote:
I choose to feed the solenoid from a lighted switch on the dash so I could manually control the charging times and the connection between the TC batteries and truck batteries . I didn't like the idea of continually pumping 14+v into a fully charged deep cycle battery which is what happens when the solenoid feed is connected to an ignition-on feed. Comments ?
Two comments:
-- Manual switches get forgotten. Ignition controlled switches prevent a charge from solar/shore power ever reaching the starter batteries. (Can be important if your camper ever sits for very long.) An intelligent relay, such as those made by Blue Sea, solves all of these problems very elegantly. Like others, I like Blue Sea products.
-- You won't be pumping current into a fully charged battery. Your vehicle's voltage regulator will throttle back as the internal resistance of the battery rises.
Basically, you want the batteries combined when under charge and separated when discharging.
Yes manual switches can be forgotten , that's why I use a lighted switch to help me remember.
Why would you not want solar/shore power from reaching starting batteries if you have 3 stage charging ?
Have you ever checked the voltage going to the starting battery after the engine has been running for several hours ? It's usually close to 14v , not near float charging.
Basically you want the batteries combined under charge and separated under discharge , but not always .
A more sophisticated system than mine would be better for sure , but at what cost .
44,071 PostsLatest Activity: Aug 30, 2026
