DiploStrat
Mar 16, 2016Explorer
Not a big deal if you are carrying a camper AND the wiring between the starter battery and the camper battery is large enough (low enough resistance) for the alternator to "see" the camper battery.
Wire up with normal wire, like 6 AWG and the camper battery may not draw down the starter battery fast enough to prevent the truck going into econo mode.
To recap: to keep a camper battery happy, you need:
-- Constant voltage/variable amperage. (The voltage of your truck should be as close as possible to the absorb voltage of your camper battery.)
-- A low resistance party between the starter and camper batteries so that they appear to the alternator as simply one big battery.
And, of course, the batteries need to be isolated when not under charge.
44,071 PostsLatest Activity: Aug 30, 2026
