mbloof
Mar 20, 2016Explorer
Personally, I'd go with a Yamaha/Honda 1K or 2K (if you want to run the air) over anything that runs off propane. While a built in generator offers on/off switch simplicity for operating the generator propane can be a limited resource that your heating, cooking, hot water and most importantly the fridge/freezer require for operation.
Where I live propane is not sold at every gas station and a 1 gallon gas can is much easier to fill then the on board propane tanks. When the generator and gas can is empty you'll still be able to use all your propane appliances however if you run out of propane you'll need to refill to use most of the appliances.
44,071 PostsLatest Activity: Aug 30, 2026
