silverbullet555 wrote:
Still sorting this camper out. I have about 30 days before I have to return this generator. I tried to run my shop vac too which overloaded the generator.
It seems I ought to look for a 2000 watt generator to replace this one with as this must be too lite.
The fridge needs to be sorted out. It runs fine on shore power. When I hit the gas switch, it doesn't illuminate to indicate gas is going to the unit. I would like to get it working and that is on the list.
It's a norcold 442 I believe and is a 2 way fridge.
If your trying to run gas while hooked to shore power you must turn the AUTO switch OFF. If Auto is on the fridge will always connect to shore power if it is available.
