69_Avion
Jun 10, 2014Explorer
harold1946 wrote:
Generator first, and add a second battery, solar later. Gennys work the same in all weather conditions, solar does not.
Those worksheets for sizing a solar system are pretty much a waste of time and energy. Go big or go home unless you are strictly a fair weather camper.
Solar equipment is at its lowest cost per watt in history, and can be built in stages if need be.
In a TT you are quite limited in space for batteries so the larger the solar array the better. The object is to fill the reservoir faster than it is being consumed.
I agree. Besides, solar won't run the AC. If you get a good solar setup and the conditions are right where you don't need the AC, then the solar is the way to go. Unfortunately, the conditions aren't always "right". Start with a good generator and then get solar when you can.
44,056 PostsLatest Activity: May 04, 2014
