coldchuck
Jun 12, 2014Explorer
JiminDenver wrote:
Generators run up there, just not as well. There is a loss for elevation and heat so 8500 ft is around the limit for running a 13.5 air conditioner with a 2800w inverter or even a pair of 2000w. My 3500/4000 open frame will do it at 10,000 but not while charging too.
Maybe I missed somewhere, have you installed hard start kit in your A/C unit and high altitude kit in your carburetor? It worked well for me and yes I got 3500/4000 as well and it can run 15500 BTU A/C, fridge, charge batteries all at same time at altitude of 11,000 feet. I still have to turn off a/c to use microwave. I installed Supero kit and high altitude jet in my carb. The negative thing is when using generator below 5000 ft, I need to switch out the main jet to larger original size. So I can't lose this jet so I put it in a bag and put into toolbox.
Chuck
44,056 PostsLatest Activity: Jan 12, 2020
