Terryallan wrote:
Something else to think about. IF you chose the TT. You can remove the WDH, which will let the front of the TT down some, and raise the rear, which may just give you the clearance you need.
Having dragged my TT once, and having seen a MH with the rear wheels almost completely off the ground with the rear overhang holding up the MH. I fully understand your concern. you will never know until you try it.
I was thinking the same thing...if it is close that would certainly help. Tv will be. 2013 ram 3500 so squat will likely be minimal but every little but might help
