towpro
Mar 01, 2017Explorer
does the blue sea only switch the Hot side?
I the hot wire between Coach AC and Inverter AC (neutrals tied together).
I found if the camper was plugged in to AC (coach power), and the inverter was turned off, and the SPDT switch switch set to coach power, and the line from SPDT switch to inverter (hot) was still plugged in, the GFI in my garage my camper was plugged into would trigger off.
so I just unplugged the wire from switch to inverter when I would unplug the inverter. (it was not wired wrong, I checked several times)
when I do this to my new camper (this weekend) I will switch both Hot and Neutral, but keep grounds common.
