StirCrazy
Jun 05, 2021Moderator
most of the sway control in hitches is snake oil, sway is cause by inproper loading (not enough tounge weight. you want over 10% of the trailers weight on the ball, and if you can sneek it closer to 13 - 14% even better. with the trailer level and that much weight on the ball you shouldn't ever need any sway control, but if you do just buy a weight distribution hitch that you cn add it on later. in 38 years of towing, I only ever had sway once and it was when I was 16 and brand new to towing and I quicky learned how to load my little trailer I had art the time.
Steve
Steve
