- valhalla360NavigatorEnclosing the underbelly is not about towing. It is to insulate the underbelly (to a degree). A bigger issue with winter camping where it helps stop the tanks from freezing but even in summer it will help a bit.
We like the slide toppers as it keeps rain and debris off the top. If you camp in the woods without a topper, you have to sweep the branches and leaves off before pulling the slide in. With the slide topper, you generally don't have to do anything. Plus it helps with cooling as the top of the slide is shaded. - Camper76Explorer
ScottG wrote:
Find out what topper the dealer is installing and check the model number on-line. It's probably fine but some factorys, like Northwood, buy a sub-par CareFree unit that is only available to them. It's such a POS that it's not worth having.
What company is good? - ScottGNomadFind out what topper the dealer is installing and check the model number on-line. It's probably fine but some factorys, like Northwood, buy a sub-par CareFree unit that is only available to them. It's such a POS that it's not worth having.
- coolmom42Explorer III wouldn't pay for enclosing the belly, but the slide topper is worth having.
- SoundGuyExplorer
Camper76 wrote:
Will enclosing the belly make a different towing?
Zero. Don't waste your $$. :(
44,059 PostsLatest Activity: Mar 18, 2026
