jgschmieg3's avatar
jgschmieg3
GFCI Keeps Tripping
On our last trip, the GFCI outlet inthe bathroom tripped on our 2014 Keystone. After a rest all seemed well. Later in the day it tripped again. It has stayed tripped ever since. From what I can tell there are at least 5 outlets daisy chained on this one outlet, so none of them work.
I have:
Replaced the GFCI outlet with a new one. Still trips.
Looked inside every outlet and insured no lose wires. Still trips.
I should also add that I got the GFCI not to trip by removing all the outlets from the GFCI box, but once I put the second white wire back in it trips.
What am I missing here?
  • One other thought: GFI outlets can go bad. I'm not an electrician and I have no idea how to test the outlet, but before you start replacing big things maybe have an electrician check the outlet. Just saying.
  • It's probably the fridge's heater that's tripping it. Try unplugging to see if it still pops - if so then replace the element.
  • bob213 wrote:
    Where are you plugging in at to test this? If at home and you are on a GFI protected circuit from the house sometimes they don't play well together with the trailer. If at a campground, I would check for a loose wire on the converter.
    Thanks. I will look at the converter. I added a little to my comments above.
  • Where are you plugging in at to test this? If at home and you are on a GFI protected circuit from the house sometimes they don't play well together with the trailer. If at a campground, I would check for a loose wire on the converter.(actually the circuit breaker)
