#1Flyboy wrote:
... Do you have an inverter in your RV? I had the SAME problem; had to reset 1 of the 2 circuit breakers on the inverter to get the outlet to work...For some reason they ran the outlets thru the inverter, and yes, I was plugged into 50A at the time... Your setup might be different than mine, but after spending a day trying to resolve the problem, this was a easy solution to my problem!!! Good luck...
The OP has an Outback trailer, which according to my review, does not have an Inverter with AC power wired through it. He REALLY NEEDS TO START with an examination to see if his shore power is even working.
