pattycamper's avatar
pattycamper
GFI not working-blew 2 30 amp service fuses
On my last trip, someone flooded the sink and water flowed over into GFI (GFI is on front of sink cabinet). Tried to turn on AC later and it wouldn't turn on (just hummed). I didn't immediately put 2 and 2 together, but after trouble shooting I found both 30 amp fuses were blown for 30 amp service. Replaced them and tried to reset GFI, but it wouldnt and no GFI outlets worked. This outlet is the only one with reset on it. I got home, replaced GFI, still nothing. None of the GFI's work. Now when I try to plug anything in, it flips the generator breaker, but fuses dont blow.
I've reached the end of my trouble shooting skills. Everything was working before the trip, so I am pretty certain the water caused the issue. Any ideas for thinks to look at??
Thanks,
Patty in AZ
  • well, you should add a meter to your "trouble shooting skills set"... :-)
    with your "new meter", check that you have 110v AC coming into the breaker (testing your new skill). Then check that you have 110v AC leaving the breaker. Similarly check the same at the GFI and go from there. Maybe you didn't reset the breaker correctly... some have to be fully toggled to off and then back to on.
    Does any AC services work in the trailer?
