nextlevel wrote:
It just started this.
Well then SOMETHING has changed.
Most likely your "foundation" has shifted a bit.
IF....there is no spring tension on the door (in the hinges), that's about all it can be.
I'm a bit reluctant to mention this.......but if it has traditional hinge pins like a house door, you can take out one of those pins and put a little bend in it with a hammer and then it will stay where you leave it, open, closed or half way in between.
