Bigbird65 wrote:
Lynnmor wrote:
I level the trailer frame as close as possible using a 4 foot level. Then I attach 2 levels on opposite corners using 3M VHB tape. Now I can detect frame twist when deploying the stab jacks. If I found that appliances were not level, I would fix them rather than tilting the entire trailer.
This post confused me. I don't understand what you do to fix appliances that are not level. Are you saying that with the trailer level, the appliances are out of level enough to not work properly?
I'm not the one that levels trailers by using the appliances, but you often read this method on this forum. Rarely will you find that the stovetop or the fridge off enough to matter. If I had an appliance that cock-eyed, I'd fix it.
