Bigbird65 wrote:
hohenwald48 wrote:
I just drilled holes and mounted mine with screws. I guess I don't see why that's a problem. With proper caulk it's not going to leak and there are screw holes all over the sides of the TT where it was assembled so I don't figure a couple more are going to ruin the thing. Plus, if it ever needs replacement it will be a lot easier to remove than one with yards of double stick tape under it.
If you look back at the photos on the previous page mine is easily replaced by removing the 4 screws. I used a total of 10" of double sided tape, not yards. It looks better not having to use caulk. Screws are fine if that is what you like. Guess you didn't read it very closely.
I was responding to the OP. Not commenting on your particular installation. Sorry you took it as a personal criticism.
