Mike_Up
Aug 07, 2013Explorer
I agree with the others, I don't see any contact with the gel coat sandwiched wall. Good thing because you'd be getting a new wall if it had.
That's why I went stick and tin because after being at the StarCraft factory and seeing an entire wall replaced for $8000 ($4000 wall, $4000 labor) after it was hit in an accident. I wouldn't want to deal with that headache. Sure it could had been fixed half @ss but it was new and the repairman at the factory said this was the only way to correctly fix damaged laminated walls, 'replacement'. He said if it were stick and tin, most it would be would be a grand.
But you do have protection from hail damage. I wanted protection from delamination that I see so much.
Good luck with it and I'm happy to see only access doors were damaged, and not your body.
Stay safe.
Stay safe.
44,056 PostsLatest Activity: May 04, 2014
