MainerBobExplorerSep 16, 2017Glow PlugsLast year my check engine light went on. Went to dealer and was told I had a bad glow plug but it was not necessary to fix it right away and when I did I should just do all 8 since if I had one bad o...Show More
Charlie_D_ExplorerSep 17, 2017Most LBZ 2006 glow plugs are easy to reach from under the truck. Mentioning the wire-OP might check to see it the nut holding the wire on is loose.
Related ContentGlow plug replacement Pleasant surpriseGlow plugDURAMAX GLOW PLUGBad Glow Plug?7 pin plug amperage rating?
