Lantley
Dec 21, 2015Nomad
Bigbird65 wrote:Lantley wrote:
I'm am intersted in the Glow step and may purchase a set before next season. My concern is. How hard are they to set up. How much effort does it take to level steps with the grounds supports on the bottom step.
Do you have to use ground support every time?
I keep mt RV at home if I were just going to the RV to get something out of it would I have to fully deploy the steps including ground support legs. Or could I lower steps with out leg for quick one trip in and out use.
Once they are installed it is a simple matter of removing the latching pin and lowering the steps as a unit. The upper step is adjustable to 3 different positions. Mine is usually adjusted to the middle position.
As the steps go down the landing gear automatically deploys. It is also adjustable in case the ground is not level.
Since my trailer is stored in my back yard I leave the steps down until we are ready to leave on a camping trip. I think you will really enjoy using them. We have.
Thanks Bigbird I get it. It appears leaving step down at all times when at home will address my concerns.
44,070 PostsLatest Activity: Jul 01, 2022
