Lantley
Mar 06, 2016Nomad
I am a bit late to the party, but I was also chosen to be a tester.
I installed my GSR's a few days ago. I may have benefited from the recent improvements. Because I had no issues installing step. I was able to use existing holes and everything lined up fine.
Steps do require more effort to set up than traditional step. But in the end the difference is negligible. The GSR's are also slightly narrower than my OEM steps, but the smaller width does not seem to be an issue thus far.
The ability to adjust the steps to meet the ground more than makes up for the width and additional set up effort.
The GSR steps are very smooth and easy to adjust. The latching mechanism is easy to operate. The locking pin is attached with a cable
I had a slight discrepancy determining the correct size steps for my unit. However that issue was resolved and Torxlift will be changing there order forms to avoid future issues.
In the end the GSR's are a real game changer. The impact of walking down the steps is transferred to the ground. There is no shaking or wobble while walking up or down the steps. The GSR's are without a doubt provide more stability than traditional steps.
The stability creates an overall safer experience when using the steps. Torxlift appears to have a winner. I am impressed with the new steps so far.
44,070 PostsLatest Activity: Aug 05, 2026
