Reisender
Oct 21, 2020Nomad
Groover wrote:
electric hummer on youtube:
jerryrigeverything
TFL trucks
Neat features
T-tops haven't seen those since Smokey and the Bandit
air suspension
16" max ground clearance
4 wheel steer
200kwh battery
each rear tire has its own motor
350kw charging capable for 35 minute charging (not for use at home)
Drawback
Tiny bed
The 350 KW 800 volt charging is a big plus for a vehicle with a battery that big. 350 KW charging facilities are rather rare right now. I think Electrify America and Canada are the only ones on this side of the pond to have any and that is usually only one one out of 6 “pumps” at a location. But this is the second manufacture to use that format (Porsche being the other) so at least they won’t be tied up much.
Good to see GM push the envelope a bit. Now they need to do a Bolt remake and actually start producing them in numbers.
