Desert Captain wrote:
Some Of the 5.3' s come with too tall of a rear end (3.42-not designed to tow), but my 3:55 did just fine with the limited slip diff. A 3:73 would be even better. If you can find a 5.4 with the 6 speed trans/ 3:73's you will blow the doors off of 5.3.:B
Of course the 5.3 w/ 3.42 gears are designed to tow. That is GM's towing gear in 1500 trim w/ the 5.3, and it does just fine with the 6 spd transmission. In fact, that combo tows a lot better than the old 4 spd w/ 4.10 gears (check my signature to see how I know!).
The non-towing gears are the 3.08 -- you want to steer clear of those.
