the_bear_II
Jul 31, 2013Explorer
Try a product called Restore available at autoparts stores. I've used it on several high mileage vehicles to reduce the oil use and improve performance.
Way back when, I had a 1977 Honda Civic that had bad rings and was burNing a quart of oil with every tank of gas. The compression was so bad it would not hold in first gear on a hill with the engine off. I added restore and after 500 miles the engine used a quart of oil every 1000 miles and compression was good enough to hold on the same hill.
