ShinerBock's avatar
ShinerBock
GM Colorado bent frame towing 2,100 lbs
From a Facebook post.
"A friend of mines Chevy Colorado with 10k miles was towing a 2100# camp trailer on a dirt road and hit a bump. This is the result. GM sent out an “investigator” 6 weeks later and has denied any warranty claims. They state the “the truck has 1” taller tires as the first reason. The second reason is the trailer is 2100 pounds, in the owners manual it states that trailers over 2k pound should have brakes. (Towing capacity listed as 5k) Since hit trailer is 100 pounds overweight and doesn’t have brakes that’s what the frame bent. No other damage to truck.
GM’s investigator took trailer to a certified CAT scale. Trailer is 2100lbs. Tongue weight is 347lbs.
Think twice about that Colorado purchase if you actually use your truck as a truck."
Click link to see pictures.
Facebook post
Edit:After doing a quick Google search of "Colorado bent frame", it appears that this guy is not alone with several people pasting about bent or cracked frames in the Colorado/Canyon forums at roughly the same spot.
