DBH_MI wrote:
You may also want to take the vehicle in for service and have them check it according to service bulletin PIT5206C. You may be treating the symptom rather than the cause.
Next time I'm in for service I'll mention that bulletin; however, I have read feedback from dozens of people and they all pretty much report the same problem and lack of resolution from GM.
Fordlover wrote:
Glad you found a fix, though it'd be nice if GM would fix it for you under warranty.
How much was the range device?
After Promo discount it was $176 on autoanything.com
therink wrote:
Careful with this. GM may void your warranty by using an aftermarket ecm programer. If you take it to dealer, make sure you return programming to stock first.
That's the nice thing, it does not program the ECM, it only 'interacts' with it. Once unplugged there is no sign of use.
